JonnyPoPo
Sep 19, 2014Aspirant
Readynas Duo and WD2003FZEX compatibility
I received notification that one of my drives failed 2 days ago. I am concerned about getting another drive in to get me back up and redundant quickly. I am also upgrading from 1 TB drives to 2 TB dri...
Sep 23, 2014Guru - Experienced User
Hard to say if the noise is a concern or not w/o hearing it. I wouldn't be concerned about the lp stat events at this point.
You picked a high-performance drive, which uses more power and is acoustically noisier than the older "green" drive you are running.
