AaronThurling
Aug 12, 2020Aspirant
Readynas Duo constantly resynching volume
Readynas Duo RND2000 v1, the act light is constantly active, so upon checking the logs i find that the device appears to continually find and fix errors on volume C then a resync begins that takes many hours. This behaviuor loop then starts again shortly after the resync finishes and the log declares the volume fully redundant, it happens every day but i cannot find any specific info about either of the disks being faulty, and both disks are showing as OK in the status list.
I have checked the SMART logs and the only thing that is showing there that may be cause for concern is Lp stat events at around 450 other than that there are no other smart failures listed.
- SandsharkSensei
Try (with power off) removing and re-seating the drives. That can also happen if one drive wakes from sleep much slower than the other. Is one drive a "green" one and the other not? Try disabling drive spin-down (if it is currently enabled) and see if that makes a difference. Unfortunately, that can also be a sign of a failing unit, possibly just the power supply, but equally or more likely something else.
- AaronThurlingAspirantHi thanks for your reply, I actually swapped both drives in the end as they are both 10 years old. Having done so I run diagnostics on them outside of the nas environment and one showed a smart spin retry failure, so as you say it was probably due to spin up. Not sure why the smart spin retry didn’t show itself in the nas smart data readout.
- SandsharkSensei
"Smart Spin Retry" is not common to all drives. It also is typically an indication that the drive is a "green" one, and that type of problem is precisely why green drives are not recommended for NAS use, especially when used together with those that are not "green". When only one drive automatically spins down for power savings, the slowness in spinning back up can disrupt RAID integrity.
