agentred
Feb 18, 2013Aspirant
Readynas Duo Failing, Should I Pull Disks?
Hey Everyone Yesterday my Readynas Duo disconnected from the network and refused to shut down, not from the command prompt or by holding the button down, and I couldn't access the front end. I had...
agentred
Thanks for the prompt response, the ext file structure explains a lot.
The SMART status for Disk2 seems fine but that doesn't explain why some files aren't copying... I'll try robocopy and that might help.
I'll keep the drive in the duo for now. I also have a spare disk, will use that in the disk 1 slot, thanks again for your help.
For future reference though, I'm thinking of just using RAID 1 instead of X-Raid so that if this ever happens again I won't have to deal with ext....
