agentred
Feb 18, 2013Aspirant
Readynas Duo Failing, Should I Pull Disks?
Hey Everyone Yesterday my Readynas Duo disconnected from the network and refused to shut down, not from the command prompt or by holding the button down, and I couldn't access the front end. I had...
Feb 18, 2013Guru - Experienced User
RAID-1 would also use ext for the file system - All ReadyNAS products use ext for all internal drives, no matter what RAID format is used.
