pvlier
Oct 11, 2011Follower
ReadyNAS DUO getting hot, fan at low speed
A customer had a ReadyNAS DUO with a Seagate ST3750330AS 698 GB inside. It was running without problems. Recently the customer wanted to upgrade storage. I saw the WD20EARS on the HCL but couldn't pur...
PapaBear1
Aug 04, 2012Apprentice
If the fan is running at 294RPM, there is definitely something wrong with the fan system. Going back and reading your first post, yous stated that the old disks was at 64 degrees Celsius, which is way beyond normal.
Open an on line technical support ticket. The Duo may still be under warranty.
What is the status of your backup?
