pvlier
Oct 11, 2011Follower
ReadyNAS DUO getting hot, fan at low speed
A customer had a ReadyNAS DUO with a Seagate ST3750330AS 698 GB inside. It was running without problems. Recently the customer wanted to upgrade storage. I saw the WD20EARS on the HCL but couldn't pur...
rnuser
Aug 04, 2012Aspirant
It's 4 years old, so out of warranty. And support suggested I buy a new unit.
I thought I'd ask on this forum first, if there was a way to make it work without "bricking it" over the fan, especially since this previous person had the same problem. The old disk was running at a fine temperature, it was the new ones only that triggered the overheating. Could be having two drives makes it overheat (which seems like a big design flaw and I'm sure others run the Duo with two drives). Could be the type of drives or could be the firmware upgrade, too.
Was trying to make sure I covered all my bases first before an expensive replacement.
Thanks.
Thanks.
