pvlier
Oct 11, 2011Follower
ReadyNAS DUO getting hot, fan at low speed
A customer had a ReadyNAS DUO with a Seagate ST3750330AS 698 GB inside. It was running without problems. Recently the customer wanted to upgrade storage. I saw the WD20EARS on the HCL but couldn't pur...
PapaBear1
Aug 04, 2012Apprentice
If you have a can of compressed air, remove the back panel and give a little blast to the fan. It should spin freely. If it does not it indicates the fan may be at fault. If it does, then the controller is bad. That is of course on the motherboard, so it would indicate a replacement unit.
Backup - what is the status of the backup?
