OZrevhead
Nov 04, 2015Aspirant
ReadyNAS Duo has stopped working
Hi, I have a ReadyNAS Duo RND2000 v2 with 2 1TB drives, I tried to access it today and its not on my network map anymore. It was silent with network activity lights flashing and no lights on the front...
Nov 04, 2015Guru - Experienced User
Many v1 users mistakenly think they have a v2. There's guide here you should check: http://www.rnasguide.com/2012/01/09/how-to-tell-whether-i-have-a-duo-v1-or-duo-v2-or-nv-v1-or-nv-v2/
The LED code for the duo v1 is below. I'm not sure if it is the same for the v2.
LED blink behavior for 2 disk systems is three quick blinks of all disk LEDs and the backup LED, followed by a 1 second delay, followed by a number of slow blinks. The number of slow blinks will be the error code.
Current error codes:
1 – Vendor mismatch
2 – No disks detected
3 – Bad contents on root partition of disks
4 – Flash error
5 – Unsupported RAID configuration
