Abernus1
Apr 04, 2014Aspirant
ReadyNAS Duo HDD replacement
Hi all, I have been using my ReadyNas Duo V2. This has been running for a while with 2 WD WD10EARS 1.0Tb drives. However one of the drives started showing a large number of errors so I have power...
Apr 04, 2014Guru - Experienced User
It also has a 3 year warranty, while the others only have 1 year.
Abernus wrote: Thanks for the info, the HDD you have suggested is only £10 more than the others so wont break the bank.
