Abernus1
Apr 04, 2014Aspirant
ReadyNAS Duo HDD replacement
Hi all, I have been using my ReadyNas Duo V2. This has been running for a while with 2 WD WD10EARS 1.0Tb drives. However one of the drives started showing a large number of errors so I have power...
hillclimber57
May 26, 2014Aspirant
Do you happen to know if these drives you recommend also work OK in a ReadyNas Duo RND2000-100N?
thanks
thanks
