stevo_b
Jun 02, 2017Follower
ReadyNAS Duo not expanding
Hello My ReadyNAS Duo will not automatically expand, even althought I have bought Hard Drives that are on the capability list and I have re-booted 10+ times. Further info: I recently had a 2...
Jun 02, 2017Guru - Experienced User
There are a couple of tips here: http://home.bott.ca/webserver/?p=550
If they fail - The brute force way is to copy off the data (fastest over a gigabit network), and then do a factory reset. The reset can be done from the Web UI (which is a bit easier than dealing with paper-clips).
Then restore the data from backup after the reset completes.
