NikkD
Dec 23, 2018Aspirant
Readynas duo Powers down and wont start after installing Hard Drive
I recently purchased 3 readynas duo rnd2110v2 devices from an auction. They came with no drives so i purchased a 1TB Seagate Barracua ST1000DM010 3.5 IN SATA HD.
Now the devices power up fine wit...
- Dec 25, 2018
NikkD wrote:
On the front side, bottom right it states "ReadyNas Duo"
Then underneath it states ReadyNas followed by a sticker that says "RND2110" followed by V2
Ok. So that is a sparc platform, which we call a Duo v1 here. The v2 means it is hardware revision 2 (of the Duo v1). It is confusing, Netgear could have done a better job on the branding and platform identification.
12V~5A is the correct spec for the power adapter.
While it could be the adapter, I am thinking it is more likely to be a dead-on-arrival disk. If you have a spare disk available (2 TB or less) you could try that.
NikkD
Hi and thanks for the responce. I did install raidar and when its powered up it finds the nas on the network with no disks. Obviously with the disk in it wont power up.
Its something to do with the disk I belive, I did find an earlier post thats someone had the exact same problem and talked about using jumpers on the disk but didn't go into too much detail, So I'm not quite sure. I am guessing its a compatability issue with the HD
Dec 24, 2018Guru - Experienced User
It's been a very long time since I needed to change jumper settings on a disk (don't think I've ever needed to do that with a SATA drive).
It's far more likely that the disk is defective. Try testing it in a Windows PC with Seatools.
Another possibility is that the power adapter on the Duo is failing, and isn't providing enough power for the drive+NAS. It could also be a chassis failure. Though if you've tried the disk in all three Duos (with all three power bricks), then those possibilities seem very unlikely.
