DJGlukBH's avatar
DJGlukBH
ReadyNAS Duo RND2000 v2 unlock
Hi,   I've bought a used ReadyNAS Duo V2 and it's a great device. Unfortunately, previous owner got it registered and no longer has access to email that he used...   I've reset the device according t...
  • JohnCM_S's avatar
    Apr 09, 2019
    Hi DJGlukBH,
    We cannot change the registration of the NAS since the warranty is for the original purchaser only and it is not transferrable. You should still be able to use the NAS even though it is not registered under your email address.
    I have checked the NAS model based on the serial number and it appears that your NAS is a Duo v1. You can also check this link for reference on how to determine if your NAS is Duo v1 or v2.
    You can follow the steps here on how to access the boot menu and select the factory reset option.
ProSupport for Business
