meiscc
Jul 29, 2014Aspirant
Readynas Duo RND2000 Won't Boot
Hello all.... I am having the exact same issue as this post. http://www.readynas.com/forum/viewtopic.php?f=24&t=74110 There was never an answer as to if the problem was fixed so I'm hoping for so...
Jul 29, 2014Guru - Experienced User
Let's start from the beginning.
What duo model do you have (v1 or v2)? (check this: http://www.rnasguide.com/2012/01/09/how ... -or-nv-v2/) The labels are misleading!
Also, do you know what firmware you have installed?
Finally, do you have a windows PC?
