meiscc
Jul 29, 2014Aspirant
Readynas Duo RND2000 Won't Boot
Hello all.... I am having the exact same issue as this post. http://www.readynas.com/forum/viewtopic.php?f=24&t=74110 There was never an answer as to if the problem was fixed so I'm hoping for so...
meiscc
Jul 30, 2014Aspirant
Hi StephenB,
It is a v1. Unfortunately, I am not sure what firmware is installed on the unit. I do have a Windows PC.
I actually installed a LInux VM on the pc. I was able to see the hard drives and certain folders on the
hard drive but really don't know how to use VM. I was able to copy the folders onto th PC but when
I opened the folders on the PC, they were empty.
