Alfred_manner
Feb 14, 2024Aspirant
Readynas Duo RND2150 not working as a NAS
Hi so I'm in the market looking for a basic Nas that works, originally I purchased a Western digital my cloud EX4 which I later found was no longer supported so I cancelled my order, so I recently pur...
Feb 15, 2024Guru - Experienced User
Alfred_manner wrote:
My problem is, I can't access it as a network attached storage device in my networks, it is on the same workgroup (WORKGROUP) it's shows up as a storage Readynas Duo RND2150 but when I click on it, i gets aninterrupted action error.
Clicking on that icon doesn't do what you think. It's trying to open your browser, not file explorer.
Try entering \\192.168.1.242 in the file explorer address bar (being careful to use the correct slash). That should show you the list of shares. If/when you are prompted for credentials, make sure you enter credential for a user account that is set up on the NAS. (Admin will work, but generally it is better to set up a different user account).
- Alfred_mannerFeb 15, 2024AspirantTried that and I get a Windows can't find \\192.168.1.242 check the spelling and try again. Error :'(
- StephenBFeb 15, 2024Guru - Experienced User
Tried that and I get a Windows can't find \\192.168.1.242 check the spelling and try again. Error :'(Odd because that is the IP address that Windows is showing for the NAS in your screenshot. You might want to double-check that IP address.
In any event, Netgear discontinued your NAS back in November 2011, so it is at least 12 years old. It was a good NAS its day, but that was a long time ago. The transfer speed for large files is around 20 MB/s, so about what you'd expect from a USB-2 drive. So if you are looking for good performance, you probably should get a current NAS instead.
Note the v2 you thought you were getting was discontinued in 2013, so it would also be outdated.
- saudadeFeb 15, 2024Apprentice
Do you think the HTTPS is the issue?
When I double click on my Duo in File Explorer, I do get the shares (sort of). I do have ReadyDLNA enabled so it shows the Music, Pictures and Video folders (under my Media Share). Browse folders has the Media and Backups Shares (also visible under the tree in the left nav pane.
I did apply the workaround regarding the Virtual.conf file so mine show http://<ip-address>.
If I look at the properties of the Duo in Explorer I see this (note mine says HTTP:)
