tdibratto
Sep 26, 2019Aspirant
ReadyNas Duo upgrade path
Hi folks my READYNAS DUO is getting old and I cannot even access it any longer from Windows unless I activate and turn on the old SMB1 protocol. Windows then disables it again as it's not secure. I...
Marc_V
Sep 26, 2019NETGEAR Employee Retired
Welcome to the Community!
It would be best to go with the OS 6 Uints like the RN400 Series and up. There is a migration guide on how you can access the data on the new NAS. Support will assist you on this.
You just need to check on this KB Article. This is the procedure for your ReadyNAS Duo to an OS 6 Unit.
HTH
Regards
Sandshark
Sep 26, 2019Sensei
Rather than move the drives, you may want to consider using new drives in the new NAS. Then, use an RSYNC backup to copy the data from old to new. Finnally, re-designate your old NAS as your backup. I don't even have SMB enabled on my backup NAS, just RSYNC. I figure it's one more possible barrier to malware/ransomware -- it can't get there via a Windows machine.
- StephenBSep 27, 2019Guru - Experienced User
FWIW, I"ve done the same. My own Duo is a secondary backup of some of my RN526x shares. Rsync is enabled on it, but SMB (and NFS, AFP) are disabled. It's also on a power schedule, which creates another barrier for malware/ransomware.
- tdibrattoOct 01, 2019Aspirant
Thanks for the feedback. Wasn't expecting to have to spend upwards of $1,000 to address this. I have to wonder why I would not just buy a desktop with capability to hold 2 drives and install Linux and Samba on it. That way as Linux and Samba get upgraded I keep my investment. Upgrading to another Netgear running OS6, what prevents it from becoming another door stop?
- StephenBOct 01, 2019Guru - Experienced User
You have a free option, which is just to enable SMB 1 on the PC.
And if you reuse your current disks, you can get an RN212 for $400 (not > $1000).
The Duo v1 was released in 2008 - back when Microsoft Vista was the mainstream operating system; and when the largest disks on the market were 1 TB. It was replaced in 2011, because the hardware was no longer competitive.
You've gotten 8-11 years of service from it. But it's long past it's end-of-life.
As I said, mine still works, and I do still use it as a secondary backup. But when it fails, I'll just take it out of service.
