zimmermannraph
Dec 30, 2013Follower
ReadyNas Duo V1 3T WD
How to install the 3T WD The ReadyNas Duo see only one part of the drive 738 Go of the 3T. ReadyNas Duo (4.1.13) Thanks' for your help
mdgm-ntgr
Dec 30, 2013NETGEAR Employee Retired
That's expected. 2TB drives are the max supported by the Duo (v1) as there is no GPT support for Sparc models.
