JimboFoster
May 12, 2014Aspirant
ReadyNAS Duo v1, etherne flashing green fixed amber= no see?
Hi my ReadyNAS Duo v1 has been working for many years really well, that is until this weekend. It has two 2Tb HDD that are Raided. I also have a ReadyNAS Duo v2 with one 4Tb HDD, that is also workin...
mdgm-ntgr
May 12, 2014NETGEAR Employee Retired
Can you see it if you do a direct-connect? Can use a standard ethernet cable for this. Also note with a direct-connect the NAS will take the I.P. 192.168.168.168.
