JimboFoster
May 12, 2014Aspirant
ReadyNAS Duo v1, etherne flashing green fixed amber= no see?
Hi my ReadyNAS Duo v1 has been working for many years really well, that is until this weekend. It has two 2Tb HDD that are Raided. I also have a ReadyNAS Duo v2 with one 4Tb HDD, that is also workin...
May 15, 2014Guru - Experienced User
Well, possibly the hardware has failed - in which case the reset won't work. Or perhaps the OS partition got full (if you've been running it for many years, and never deleted logs, then that might have happened).
It's possible to get in through the support interface if you know how, but rebuilding it is the direct approach. You probably could also check to see how full the OS partition is, since Linux Reader can see it.
