craigygordon
May 17, 2023Aspirant
ReadyNAS Duo V1 just sits there with the fan full pelt after power cuts
Hi all hoping you can help me. I recently (6 months ago) dusted off this NAS and loaded it up with 2 disks. It was working flawlessly up until last week where after a series of power cuts it now ju...
May 18, 2023Guru - Experienced User
Try powering down, and removing the disks (label by slot, so you know which is which).
Then power up, and see if RAIDar finds it (reporting a no disks status).
- craigygordonMay 18, 2023Aspirant
Gave this a go and kept scanning for 30 mins plus and nothing đ
- StephenBMay 18, 2023Guru - Experienced User
Did RAIDar find it before the power problem?
Are you seeing a blinking light pattern on the LEDs?
LED blink behavior for 2 disk systems is three quick blinks of all disk LEDs and the backup LED, followed by an 1s delay, followed by a number of slow blinks. The number of slow blinks will be the error code. Current error codes: 1 - Vendor mismatch 2 - No disks detected 3 - Bad contents on root partition of disks 4 - Flash error 5 - Unsupported RAID configurationAlso, is the ethernet LED lit on the back of the NAS?
Yes RAIDar was finding it before the issue. The blinks are 3 fast of the blue power LED the activity light as well as 1 and 2 disk all at once. This occurs exactly every 10 seconds. In between the 10 seconds the disk 1 light flickers on and off constantly.
