mr_yogi
May 18, 2013Aspirant
ReadyNas Duo v1 RAID-X Question
I have a ReadyNas Duo v1 with 2 1TB drives, however one has just died and is out of warranty, so I'm considering replacing it with a 2TB WD RED drive. Can anyone tell me if RAID -X will automatically ...
mr_yogi
Contents of partition.log (failed disk has been removed from system)
Disk /dev/hde doesn't contain a valid partition table
WARNING: GPT (GUID Partition Table) detected on '/dev/sda'! The util fdisk doesn't support GPT. Use GNU Parted.
Disk /dev/hde: 999.9 GB, 999991611392 bytes
255 heads, 63 sectors/track, 121575 cylinders, total 1953108616 sectors
Units = sectors of 1 * 512 = 512 bytes
Disk identifier: 0x00000000
Disk /dev/hdc: 999.9 GB, 999991611392 bytes
Disk identifier: 0x62207372
Device Boot Start End Blocks Id System
/dev/hdc1 2 4096001 2048000 83 Linux
Partition 1 does not end on cylinder boundary.
/dev/hdc2 4096002 4608001 256000 82 Linux swap / Solaris
Partition 2 does not end on cylinder boundary.
/dev/hdc3 4608002 1953092233 974242116 5 Extended
/dev/hdc5 4608003 1953092233 974242115+ 8e Linux LVM
Disk /dev/sda: 1000.2 GB, 1000204886016 bytes
255 heads, 63 sectors/track, 121601 cylinders, total 1953525168 sectors
/dev/sda1 1 1953520064 976760032 c W95 FAT32 (LBA)
