mr_yogi
May 18, 2013Aspirant
ReadyNas Duo v1 RAID-X Question
I have a ReadyNas Duo v1 with 2 1TB drives, however one has just died and is out of warranty, so I'm considering replacing it with a 2TB WD RED drive. Can anyone tell me if RAID -X will automatically ...
mr_yogi
May 20, 2013Aspirant
So I assume from my partition.log my array is not 4K aligned?
I've just ordered a 2TB WD Red, so I can just slap it in when I receive it, and he array will be rebuilt as a 1TB Mirror. Then in the future when the remaining 1TB Seagate fails I can replace it with another 2TB drive and do a factory reset to rebuild the array as a 2TB 4K aligned mirrored array?
I've got my NAS backed up to an external USB drive, does the ReadyNAS have a simple utility to restore from USB once the factory reset has been carried out and the 4K aligned 2TB array has been created?
