Dougal1709
Feb 09, 2019Follower
ReadyNas Duo V1 takes hours to boot up
I have an old ReadyNas Duo V1 with a couple of 1TB disks in. There's about 600GB worth of data on it. When I start it up, it takes about 5 hours to do teh disk check. Is this normal as it's incred...
Sandshark
Feb 09, 2019Sensei
No, it's not normal. I suspect one or both of your drives is failing. Have you checked the SMART stats?
If you don't have a current backup of the data, now is a good time to do it; before it's too late.
