njd's avatar
njd
ReadyNas Duo v1 UPS comms error
I recently acquired an MGE NOVA AVR 625 USB (EATON) UPS and the NAS keeps sending alarms every minute:
UPS event detected. (readynasduo)
UPS has been disconnected.
System log showing errors:
usb 2-2: USB disconnect, address 3
usb 2-2: new low speed USB device using uhci_hcd and address 5
Health shows:
UPS 1 EATON NOVA AVR, Battery charge: 100%, 48 minutes OK
But shortly after:
UPS 1 Not present
(log extract follows)
Feb 2 18:30:11 gandalf hidups[12041]: Startup successful
Feb 2 18:30:13 gandalf upsd[12049]: Connected to UPS [UPS]: hidups-hiddev0
Feb 2 18:30:13 gandalf upsd[12050]: Startup successful
Feb 2 18:30:14 gandalf upsmon[12062]: Startup successful
Feb 2 18:30:14 gandalf upsmon[12062]: Warning: running as one big root process by request (upsmon -p)
Feb 2 18:30:14 gandalf upsd[12050]: Client monuser@127.0.0.1 logged into UPS [UPS]
Feb 2 18:30:15 gandalf kernel: hdc: cache flushes supported
Feb 2 18:30:15 gandalf kernel: hde: cache flushes supported
Feb 2 18:30:16 gandalf kernel: chn=0, statu/LP_S=0x(d0/d050)29, 32
Feb 2 18:30:57 gandalf kernel: usb 2-2: USB disconnect, address 3
Feb 2 18:30:58 gandalf kernel: usb 2-2: new low speed USB device using uhci_hcd and address 4
Feb 2 18:30:59 gandalf hidups[12041]: read error: Input/output error
Feb 2 18:30:59 gandalf hidups[12041]: Waiting for UPS to be re-recognized...
Feb 2 18:30:59 gandalf kernel: usb 2-2: configuration #1 chosen from 1 choice
Feb 2 18:31:01 gandalf kernel: hiddev96: USB HID v1.00 Device [EATON NOVA AVR] on usb-0000:00:17.0-2
Feb 2 18:31:02 gandalf hidups[12041]: UPS communicating again after 4 seconds.
Feb 2 18:31:02 gandalf upsmon[12062]: Signal 15: exiting
Feb 2 18:31:02 gandalf upsd[12050]: Signal 15: exiting
Feb 2 18:31:03 gandalf hidups[12041]: Signal 15: exiting
Feb 2 18:31:04 gandalf kernel: hdc: cache flushes supported
Feb 2 18:31:04 gandalf kernel: hde: cache flushes supported
Feb 2 18:31:09 gandalf RAIDiator: UPS event detected. (gandalf) : UPS has been disconnected.\n[Sat Feb 2 18:31:06 WET 2013]
Feb 2 18:31:11 gandalf hidups[12253]: Startup successful
Feb 2 18:31:13 gandalf upsd[12260]: Connected to UPS [UPS]: hidups-hiddev0
Feb 2 18:31:13 gandalf upsd[12262]: Startup successful
Feb 2 18:31:15 gandalf upsmon[12274]: Startup successful
Feb 2 18:31:15 gandalf upsmon[12274]: Warning: running as one big root process by request (upsmon -p)
Feb 2 18:31:15 gandalf upsd[12262]: Client monuser@127.0.0.1 logged into UPS [UPS]
Feb 2 18:31:15 gandalf kernel: hdc: cache flushes supported
Feb 2 18:31:15 gandalf kernel: hde: cache flushes supported
Feb 2 18:31:57 gandalf kernel: usb 2-2: USB disconnect, address 4
Feb 2 18:31:58 gandalf kernel: usb 2-2: new low speed USB device using uhci_hcd and address 5
Feb 2 18:31:59 gandalf hidups[12253]: read error: Input/output error
Feb 2 18:31:59 gandalf hidups[12253]: Waiting for UPS to be re-recognized...
Feb 2 18:31:59 gandalf kernel: usb 2-2: configuration #1 chosen from 1 choice
Feb 2 18:32:01 gandalf kernel: hiddev96: USB HID v1.00 Device [EATON NOVA AVR] on usb-0000:00:17.0-2
Feb 2 18:32:02 gandalf hidups[12253]: UPS communicating again after 4 seconds.
Feb 2 18:32:03 gandalf upsmon[12274]: Signal 15: exiting
Feb 2 18:32:03 gandalf upsd[12262]: Signal 15: exiting
Feb 2 18:32:03 gandalf hidups[12253]: Signal 15: exiting
Feb 2 18:32:06 gandalf kernel: hdc: cache flushes supported
Feb 2 18:32:06 gandalf kernel: hde: cache flushes supported
Feb 2 18:32:11 gandalf RAIDiator: UPS event detected. (gandalf) : UPS has been disconnected.\n[Sat Feb 2 18:32:07 WET 2013]
I have read about UPS nightmares but would still apreciate any hints to make UPS automated shutdown work without gettings an email every minute.
Many thanks,
Nuno
1 Reply
  • I have an Ultra4 Plus connected via USB cable to a Panamax MB850 battery backup and I'm getting the same "UPS Event Detected", "UPS disconnected" messages. I'm running 4.2.21. The front panel display of the UPS does not indicate anything is wrong and I'm getting no other error messages from the NAS. When I first connected the UPS the NAS detected it right away and was working fine. Last night it sent about eight of these messages one after the other.
    Any comments or thoughts on solutions is appreciated. Thank you.
ProSupport for Business
