jchandra
May 28, 2020Tutor
ReadyNAS Duo v2 - Erase Issue
Equipment Details: - ReadyNAS Duo v2 (RND2000) - 2 x 2TB installed - RAIDar 5.3 - HDs reported as healthy by RAIDar Hi All, I have searched the forum extensively but couldn't find anythin...
May 28, 2020Guru - Experienced User
jchandra wrote:
Last night I decided to factory reset my Nas by booting into the factory default option and choosing Erase (third option).
This does a "secure erase" (multiple overwrites) and is incredibly slow. FWIW, I don't recommend ever doing this. A single-pass overwrite of the disk is currently viewed by NIST as sufficient.
jchandra wrote:
It just seems to have disappeared? I checked the lights on the unit and HD1 and HD2 are a constant blue. I am heistant to restart anything as I don't want any locked drives. But for the moment I wanted to understand if what I am seeing is normal?
I tried putting the IP direct into a browser but it didn't show the admin screen. Should I wait, or be doing something else?
Can you ping the NAS?
You won't see the admin screen, because that requires the system to be installed on the disks - and you are running under the the boot loader. Normally RAIDar should discover it, but it is possible that the system is missing some discovery requests because of the disk activity. Also, if one of the disks isn't completely healthy, it might be running into a rough patch.
At this point, I'd let it wait for a while (could take a couple of days).
jchandra
May 28, 2020Tutor
Just tried to ping, and yes, it pings - that's reassuring for me.
Yep, I've learnt my lesson and will not choose the erase option in future. I just wish the dialogue stated that this was a secure erase, I don't think I would have chosen it.
I'll report back in a few days - thanks for your help.
