Plucky
Dec 15, 2017Aspirant
ReadyNAS Duo v2 - Replacement HD
Hi Ive had my Disk 1 show a error of 'Dead' in System --> Info window so I have replace with a Seagate ST31000524AS drive. Problem I have is Im not sure its synchronizing as I still see the sam...
Plucky
Hi StephenB
Thanks for replying
It looks like its rebuilt disk 1 but now is telling me disk 2 could be faulty but the status for disk 2 is OK.
Disk 1 is showing a yelow circle with a red cross through it and status is inactive.
Dec 15, 2017Guru - Experienced User
What are you seeing in the log?
- PluckyDec 15, 2017AspirantIve tried to attach a snap shot of the log as well.Info
Disk 1 ST31000524AS 931 GB (36 °C / 96 °F, Write-cache On). Status: Spare inactive Disk 2 ST31000524AS 931 GB (35 °C / 95 °F, Write-cache On). Status: OK Fan SYS 744 RPM Temperature 35 °C / 95 °F UPS Not Present LogsDownload LogsClear LogsSat Dec 16 06:51:55 PST 2017 Detected increasing ATA errors on disk 2[ST31000524AS, 6VPGYZ8V] 162 times in the past 30 days. This often indicates an impending failure. Please be prepared to replace this disk to maintain data redundancy. Sat Dec 16 06:51:44 PST 2017 System is up. Sat Dec 16 06:51:35 PST 2017 ATA error count has increased in the last day.
Disk 2:
Previous count: 36
Current count: 161
Growing SMART errors indicate a disk that may fail soon. If the errors continue to increase, you should be prepared to replace the disk.Sat Dec 16 06:50:37 PST 2017 Your ReadyNAS device has been updated with a new firmware image. (5.3.13) Sat Dec 16 06:50:29 PST 2017 Successfully upgraded ReadyNAS Photos II addon package (version: 1.0.6 --> 1.0.6) Sat Dec 16 06:39:45 PST 2017 Volume scan found and corrected errors. Sat Dec 16 05:44:16 PST 2017 Alert test message has been sent. Sat Dec 16 05:44:02 PST 2017 Alert settings saved. Sat Dec 16 05:44:02 PST 2017 Alert contact(s) saved. Sat Dec 16 05:43:58 PST 2017 Alert test message has been s - StephenBDec 15, 2017Guru - Experienced User
There's no sign that it rebuilt disk 1 (or synced it to disk 2).
Maybe try removing disk 1, then reinserting it (with the NAS running).
Ive just removed and reseated the drive and it now says:
RAID sync started on volume C.
Data volume will be rebuilt with disk 1.
New disk detected. If multiple disks have been added, they will be processed one at a time. Please do not remove any added disk(s) during this time. [Disk 1]
I will let you know how it goes.
Thanks again.
