terriblytired's avatar
Mar 18, 2016
ReadyNAS DUO v2 - some files or folders cant be seen on any dlna device
hello all,   as in the subject mentioned i have a problem with readynas... i have a readynas duo v2 at home(and i also have the model before at home and in use and there is the same problem) to th...
  • StephenB's avatar
    Mar 19, 2016
    The dlna server creates its own media database.  Did you try forcing a dlna rescan?
    Once you login as an admin and you are at the dashboard, click CONFIGURE. In the configure screen, under services, click READYDLNA and a dialog will pop-up for setting auto scan. Click the circular arrows and it will rescan.
ProSupport for Business
