TonVH1
Nov 01, 2012Aspirant
Readynas Duo V2 & FTP
I have been reading here a bit and have the feeling that the Duo V2 does not have (as default) an FTP-server. Is this correct?
mdgm-ntgr
Nov 01, 2012NETGEAR Employee Retired
You need to be running 5.3.5 (or later) on a Duo v2 to use FTP. Previous firmware did not have a GUI option to use FTP.
Also be aware that the Duo (v1) and Duo v2 are quite different. See How to tell whether I have a Duo v1 or Duo v2 or NV+ v1 or NV+ v2
Personally I would recommend the Ultra over the Duo v2.
