Retired_Member
Mar 07, 2016ReadyNAS Duo v2 and larger then 4TB disks?
My old beta Duo v2 unit is suffering a hard drive failure, and I'm pondering what to do with it long term. Currently it has two Seagate 2TB drives. Last week, the second drive went offline which ...
Mar 07, 2016Guru - Experienced User
kohdee wrote:
OS 6 does have bit rot protection, so I am a little confused on why you don't think an RN2xx device wouldn't suit you (more RAM than RN100 series, better processor, more cores).
I think the OP was meaning to say that the v2 can't be upgraded to OS 6.
kohdee
Mar 07, 2016NETGEAR Expert
They can be upgraded to run OS 6 but it is not supported and would still require a factory default. OS 6 on 256 MB of RAM though is painful.
- Retired_MemberMar 07, 2016
What I'd like to do is get a pair of 6TB or 8TB disks to put in the Duo v2. That would let me fully mirror my Ultra 4 unit, and then factory default it to run OS 6 there.
- mdgm-ntgrMar 07, 2016NETGEAR Employee Retired
You could try it but I don't know if it would work. I think 8TB disks would be more risky than trying 6TB disks.
- Retired_MemberMar 08, 2016
I hadn't realized the lineup expanded so much, and also pushed prices down. Was at Fry's to look at new drives, and saw a 102 for $90, and a 202 for $150.
Going to rethink my overall storage setup now, and may end up replacing the Duo v2 with an OS 6 capable device.
