Retired_Member
Mar 07, 2016ReadyNAS Duo v2 and larger then 4TB disks?
My old beta Duo v2 unit is suffering a hard drive failure, and I'm pondering what to do with it long term. Currently it has two Seagate 2TB drives. Last week, the second drive went offline which ...
Retired_Member
Mar 08, 2016I hadn't realized the lineup expanded so much, and also pushed prices down. Was at Fry's to look at new drives, and saw a 102 for $90, and a 202 for $150.
Going to rethink my overall storage setup now, and may end up replacing the Duo v2 with an OS 6 capable device.
mdgm-ntgr
Mar 08, 2016NETGEAR Employee Retired
Getting an OS6 unit would be a good way to go. For use with high capacity disks I would recommend the RN202 or better yet the RN212.
