nextwavepc
Apr 16, 2012Guide
ReadyNas Duo V2 and Rsync
Hello all.. I am confused.. perplexed and baffled. I have used and installed over 20 NAS devices, with no issues what so ever. None, Never. I have setup and used RSync to backup NAS to NAS. NAS to N...
PapaBear1
Apr 20, 2012Apprentice
When they release it in the beta format we will find out. Keep in mind that a Beta is a wide user based test of a system and is NOT recommended for operational units. If you are going to use the beta with rsync to back up from another NAS with rsync, hopefully the other unit will be a more mature product not also running a Beta version of RAIDiator.
I have two NVX units, one serving as the backup target for the other. I never update Frontview at the same time or expand the units at the same time. I wait a bit, just to make sure everything is ok.
