jeffo1
Nov 10, 2011Aspirant
ReadyNAS Duo v2 disks from v1
Will it be possible to use the HDs from my ReadyNAS Duo v1 in the new v2?
mdgm-ntgr
Nov 10, 2011NETGEAR Employee Retired
Only if you backup your data first and delete partitions on the disks. Then the Duo v2 will wipe the disks and do a clean install.
Migrating the array across is not possible due to the different RAID format.
The relevant FAQ entry will likely be updated to reflect this: http://www.readynas.com/kb/faq/boot/how_do_i_migrate_disks_over_from_an_existing_readynas_to_another
