picitup
Jul 29, 2024Aspirant
ReadyNAS Duo V2 firmware update catch 22!
Hi All I have the above device and am having some fun trying to update the firmware. I have a Dell XPS13 laptop running Windows 11. I managed to access the old shares by enabling SMB1 in windows...
Jul 29, 2024Guru - Experienced User
picitup wrote:
According to Windows, the URL/port is 192.168.1.50:8200, but no browser will connect to it due to security issues. I've tried a few browsers and enabled TLS 1.0 in each, but no joy.
8200 would be for DLNA, not the web admin interface. Just use https://192.168.1.50/admin
You will need to use a browser that has TLS 1.0 enabled.
Are you certain this is a v2? The labeling is very confusing.
The original Duo (called a v1 here):
- runs 4.1.x firmware
- says "ReadyNAS Duo" on the front panel
- often has other labels that include v2.
The Duo v2
- runs 5.3.x firmware
- says "ReadyNAS Duo v2" on the front panel.
