LawlisJ1
Dec 04, 2014Aspirant
ReadyNAS Duo V2 Issues I am having.
I have owned the ReadyNAS Duo V2 for quiet some time now but have never gotten it to work correctly. I can finish the setup process correctly but if the system looses power or is shutdown it act's as...
LawlisJ1
vandermerwe wrote: Has the duo ever worked?
When do you get it?
Do you buy it new?
It works with no issues as long as the power doesn't go out or need to be powered off. I bought it i would say about 2 years ago and it was brand new. I was in japan when I bought it new
