LawlisJ1
Dec 04, 2014Aspirant
ReadyNAS Duo V2 Issues I am having.
I have owned the ReadyNAS Duo V2 for quiet some time now but have never gotten it to work correctly. I can finish the setup process correctly but if the system looses power or is shutdown it act's as...
mdgm-ntgr
Dec 04, 2014NETGEAR Employee Retired
This sounds like you could have aborted a factory default with a secure erase.
I can check this if you like.
