LawlisJ1
Dec 04, 2014Aspirant
ReadyNAS Duo V2 Issues I am having.
I have owned the ReadyNAS Duo V2 for quiet some time now but have never gotten it to work correctly. I can finish the setup process correctly but if the system looses power or is shutdown it act's as...
mdgm-ntgr
Dec 04, 2014NETGEAR Employee Retired
To the right of User Control Panel above you will see e.g. "1 new message". Click on that link.
When the disks are locked, a factory default every boot and the disks not being usable in a PC are classic symptoms.
