LawlisJ1
Dec 04, 2014Aspirant
ReadyNAS Duo V2 Issues I am having.
I have owned the ReadyNAS Duo V2 for quiet some time now but have never gotten it to work correctly. I can finish the setup process correctly but if the system looses power or is shutdown it act's as...
mdgm-ntgr
Dec 05, 2014NETGEAR Employee Retired
I haven't got a response to my PM yet.
Yes, that fix via SSH would work if you are comfortable with using that. Though the issue is that if SSH is not already enabled that installing root ssh requires a reboot so the factory default would be done before SSH could be enabled.
