aaccee
Apr 28, 2012Aspirant
Readynas duo v2, new member
Hi, new member with a few questions. I have installed 2 x 2tb new compatible drives and have raidar up and running. Q: On the Raidar panel it shows 5.3.4 under the i heading but 4.3.4 when you click ...
mdgm-ntgr
Apr 28, 2012NETGEAR Employee Retired
aaccee wrote:
Q: On the Raidar panel it shows 5.3.4 under the i heading but 4.3.4 when you click on 'about' is this normal, and is this the most up to date Raidar available?
Yes this is normal. RAIDiator 5.3.4 (shown in the Info - far right - column) is the latest firmware for your NAS. RAIDar 4.3.4 is the latest version of the application that runs on your client machine to discover your NAS, monitor it and choose RAID mode if doing a factory reset.
aaccee wrote:
Q: I do not have any indicator light under on the Raidar panel under the volume status, but there is a green volume light showing at the base of the Dashboard panel, is this normal?
You should see an indicator light in RAIDar.
aaccee wrote:
Q: I cannot add a new share on dashboard, all appears ok throughout the process, I ignore the incorrect/invalid share or character. What is the correct process?
So when you login to the NAS e.g. \\ip.address.of.nas you don't see the new share you attempted to create?
