llevet
Nov 10, 2011Aspirant
ReadyNAS Duo v2 services
Hi, I 'm just see the new Duo V2, but i'm surprise it use only CIF service !!! Why have you remove NFS (streaming to lot of media player, remote share for linux ...) and RSYNC (backup from other l...
ripface
Mar 11, 2012Aspirant
Hi All,
Not sure if this has been covered before but ..... if you want to enable ftp on the ReadyNAS Duo v2 then ....
Use EnableRootSSH to good effect!
Login as root, and cd to /etc/default
edit the services file (vi services)
Change the line "PROFTPD=0" to "PROFTPD=1"
Save the change
reboot
When the ReadyNAS reboots the proftpd daemon will start automagically. You cannot use either the root or admin logins for ftp services. You need to create a new user and home directory as follows.
useradd ftpuser
passwd ftpuser (Make it a secure one!)
mkdir /home/ftpuser
chown /home/ftpuser
Now you can login via ftp as the user ftpuser.
Have fun!
Ripface.
Save the change
reboot
useradd ftpuser
mkdir /home/ftpuser
chown /home/ftpuser
Have fun!
Ripface.
