llevet
Nov 10, 2011Aspirant
ReadyNAS Duo v2 services
Hi, I 'm just see the new Duo V2, but i'm surprise it use only CIF service !!! Why have you remove NFS (streaming to lot of media player, remote share for linux ...) and RSYNC (backup from other l...
ripface
Mar 11, 2012Aspirant
Hi mdmg,
Thanks for the feedback. Always an option using the Dashboard. I guess if the option to switch on FTP had been put there you wouldn't need to login via ssh as root at all. Does anyone have any idea *why* they switched it off by default and then prevent normal "noob" users from activating it? Seems a weird thing to do!!
Cheers,
Ripface.
Cheers,
Ripface.
