bobready
Oct 06, 2011Aspirant
ReadyNas Duo vs ReadyNasPro 2?
I have had a ReadyNas Duo at home for the last couple of years and for the most part happy with it. I need to deploy a solution such as this for a business and I was considering the Duo (like I have) ...
PapaBear1
Oct 06, 2011Apprentice
You are missing the far faster processor, the larger memory size and the vastly improved file transfer rate. While the later will not be readily apparent on smaller files but will be unmistakable on very large files. Also the maximum drive size that will be recognized in a Duo is 2TB, whereas the current limit in the Pro is 3TB, limited only by the maximum size available. When 4TB drives are available in the near future, that would be the new limit for the Pro.
I faced a similar decision last year when I was going to a second home unit and chose the NVX over a second NV+ because of the speed and file throughput as the new larger drives were not at that time a consideration. The NVX now has 2x3TB drives and 2x1TB drives.
