readynasuser561
Mar 31, 2015Aspirant
ReadyNAS Duo wrong hard drive size deteced
Hi, for a client that owns a ReadyNAS Duo (Sprac 4.1.14) the hard drives are not detected well. Installed are 2x WDC WD30EFRX-68EUZN0, these are 3 TB drives. But they are detected as two hard drives ...
mdgm-ntgr
Mar 31, 2015NETGEAR Employee Retired
This is expected. There is a known compatibility issue. The maximum capacity drives that will work with the Duo v1 are 2TB drives.
For 3TB drives you need a newer NAS.
