ateixeira
Mar 20, 2018Aspirant
wrong firmware readynas 102
Hello
my readynas was not working properly and I decided to upgrade the firmware. my original firmware was 6.1.8 and I stupidly went to the netgear site and downloaded it but 6.9.3 without reading the notes that I could not do this without going through 6.2.5. Now I can not access the storage .... how can I reinstall the firmware?
thank you so much
No, that is for legacy x86 systems.
You have an OS6 ARM system, so you'd need to use How do I use the USB Recovery Tool on my ReadyNAS OS 6 storage system?
- ateixeiraAspirant
update:
remove one hard disk to connect a pc. i see all the files that i have but they are encrypted. i have snapshot backup but i cant find the folder. it's possible to recover ?
Perhaps use paid support (my.netgear.com)
- ateixeiraAspirant
found it. was in a hidden folder.
- ateixeiraAspirant
using this option ?
https://kb.netgear.com/30267/RAIDiator-4-2-USB-Recovery-Tool
