ateixeira
Mar 20, 2018Aspirant
wrong firmware readynas 102
Hello my readynas was not working properly and I decided to upgrade the firmware. my original firmware was 6.1.8 and I stupidly went to the netgear site and downloaded it but 6.9.3 without reading t...
- Mar 20, 2018
No, that is for legacy x86 systems.
You have an OS6 ARM system, so you'd need to use How do I use the USB Recovery Tool on my ReadyNAS OS 6 storage system?
ateixeira
update:
remove one hard disk to connect a pc. i see all the files that i have but they are encrypted. i have snapshot backup but i cant find the folder. it's possible to recover ?
- StephenBMar 20, 2018Guru - Experienced User
Perhaps use paid support (my.netgear.com)
- ateixeiraMar 20, 2018Aspirant
found it. was in a hidden folder.
- mdgm-ntgrMar 20, 2018NETGEAR Employee Retired
You should be able to fix the system using USB Boot Recovery.
using this option ?
https://kb.netgear.com/30267/RAIDiator-4-2-USB-Recovery-Tool
