ateixeira
Mar 20, 2018Aspirant
wrong firmware readynas 102
Hello my readynas was not working properly and I decided to upgrade the firmware. my original firmware was 6.1.8 and I stupidly went to the netgear site and downloaded it but 6.9.3 without reading t...
- Mar 20, 2018
No, that is for legacy x86 systems.
You have an OS6 ARM system, so you'd need to use How do I use the USB Recovery Tool on my ReadyNAS OS 6 storage system?
ateixeira
using this option ?
https://kb.netgear.com/30267/RAIDiator-4-2-USB-Recovery-Tool
mdgm-ntgr
Mar 20, 2018NETGEAR Employee Retired
- ateixeiraMar 20, 2018Aspirant
Thank you very much. i install version 6.2.5 then 6.5.2 and finally 6.9.3.
everthing work fine and all data are ok. ready to use.
