readynasuser561
Mar 31, 2015Aspirant
ReadyNAS Duo wrong hard drive size deteced
Hi, for a client that owns a ReadyNAS Duo (Sprac 4.1.14) the hard drives are not detected well. Installed are 2x WDC WD30EFRX-68EUZN0, these are 3 TB drives. But they are detected as two hard drives ...
Nhellie
Apr 01, 2015Virtuoso
You can get a higher volume if you put it on flex raid and select raid 0, there is no redundancy though.
