nesta
Nov 11, 2013Aspirant
ReadyNAS Duo
New here....just got this box and I'm trying to reset it so I can 1. get access to the web interface and update the firmware 2. reset it to default, so that it can show up on my network for access...
nesta
StephenB wrote: Did you purchase new or used? Did the duo come with disks? If not, do you have disks installed?
It was bought without disks, used.
