nesta
Nov 11, 2013Aspirant
ReadyNAS Duo
New here....just got this box and I'm trying to reset it so I can 1. get access to the web interface and update the firmware 2. reset it to default, so that it can show up on my network for access...
nesta
[quote="mdgm"]You should see the light patterns shown in that link as you scroll through the boot options assuming you have the v2.
Thanks, I'd used that link to check mine at your site, and it's the V2. Underneadth it reads: ReadyNAS Duo RND2110 V2.
On the front it reads: ReadyNAS Duo.
Thanks a lot!
Thanks a lot!
