nesta
Nov 11, 2013Aspirant
ReadyNAS Duo
New here....just got this box and I'm trying to reset it so I can 1. get access to the web interface and update the firmware 2. reset it to default, so that it can show up on my network for access...
mdgm-ntgr
Nov 11, 2013NETGEAR Employee Retired
My article indicates that means you have a v1 hardware revision 2 not a v2.
If you have a v2 it would say "ReadyNAS Duo v2" on the front.
To do a factory default.
1. Power down the unit
2. Press and hold the reset button
3. Power on the unit
4. The disk LEDs will blink once at 5 seconds and again after 30 seconds. Release the reset button after the second blink (about 30 seconds).
